Brand of Prop Puller to buy?
  • AirTool
    • 4049
    • Katy, Texas
    I need to buy a prop puller. What brand should I buy? Acme, OJ, ARE?
    I'm looking at the ACME. Can anyone confirm the rotating disc on the bolt has the machined pimple on it to stay centered on the boat's shaft?
    Also, does the soft ACME travel bag provide enough protection for the prop?
    AirTool
    • 2908
    RE: Brand of Prop Puller to buy?
    This one looks like a good one at a good price:
    http://www.nettleprops.com/store/p/1...op-Puller.aspx
    • SkiTower
      • 2172
      • Clayton, NC
      I got this one from Whitelake. Worked fine for me.
      http://www.shopwhitelake.com/proppuller.html
      2007 SV211 SE
      Tow Vehicle 2019 Tundra
      Dealer: www.Whitelake.com
      • JoeCos
        • Sep 2004
        • 291
        • Nor Cal
        I use the Acme prop kit. The puller works great. The bag is flimsy and will need some padding to protect the spare prop. It sits in the storage though, so there is little chance of damaging your spare.
        Boat - 2005 Team 226 -ZR6 - Several Acme Prop's (1234, 644, 1160) Depending on occassion
        Tow Rig - 2008 Chevy Silverado - Duramax Diesel - Crew Cab
        • JUST-IN-TIME
          • 293
          • ON YOUR BOAT
          i have used both of those
          work fine
          i use my impact to get them off
          e-z
          HUMAN BUILT = HUMAN FIXED
          switchbait.com
          • AirTool
            • 4049
            • Katy, Texas
            Re: RE: Brand of Prop Puller to buy?
            work fine
            e-z
            Does the impact get 'er done so fast you don't have to block the prop? Or do you still have to block the prop somehow.
            AirTool
            • JUST-IN-TIME
              • 293
              • ON YOUR BOAT
              RE: Re: RE: Brand of Prop Puller to buy?
              no blocking so far for me
              but watch out they will pop out at u
              keep hands far away
              i use a 16" extension
              switchbait.com
              • AirTool
                • 4049
                • Katy, Texas
                Re: RE: Re: RE: Brand of Prop Puller to buy?
                keep hands far away
                I didn't think you would have to block it....but why not leave the prop nut on a bit to keep the prop from popping out? Does the impact bind the prop up against the nut before you can let off the trigger?
                • JUST-IN-TIME
                  • 293
                  • ON YOUR BOAT
                  RE: Re: RE: Re: RE: Brand of Prop Puller to buy?
                  i take the nut off with impact
                  then use the tool
                  we have also bent some tools, lol
                  switchbait.com
                  • Hollywood
                    • Sep 2003
                    • 1930
                    • WIIL
                    I understand the "time is money" concept but an impact seems like extreme overkill.
                    For those of you not making money working on boats, snug the puller up by hand (both wrench and holding the prop, no block) then tap the back (bow side) with either the wrench you just used to loosen (not take off) the nut or a small hammer and it should pop right loose. The tighter you make the puller the more it bends and puts a side load on the hub, making it MORE difficult to remove.
                    • JUST-IN-TIME
                      • 293
                      • ON YOUR BOAT
                      i use a cordless impact, mine is a mac, but harbor freight has them for like 29.99
                      switchbait.com
