Trailer - Backup Solenoid Problem
  • HS
    • Oct 2007
    • 1333
    • Sammamish, WA
    • 2010 SANTE 210 (Sold)
    I have an intermittant problem with my backup solenoid which prevents me from backing the trailer. It is a DHM trailer with a UFP solenoid and the trailer has disc brakes. The DHM folks think it is the ground wire and suggest adding a second ground wire and tweaking the connection posts. I also ordered a brake lockout cap. Has anyone experienced this problem and can you suggest a wiring or another solution to try?
  • JUST-IN-TIME
    • 293
    • ON YOUR BOAT
    RE: Trailer - Backup Solenoid Problem
    yes run another ground off the solenoid to brake master cylinder
    HUMAN BUILT = HUMAN FIXED
    switchbait.com
    • HS
      • Oct 2007
      • 1333
      • Sammamish, WA
      Thanks.
