fuel pressure/runability issues
  • frms1
    • 3
    I'M NEW TO NAUTIQUES, SERVICE MANAGER AT NEW NAUTIQUE DEALER. FIRST PROBLEM TO HIT ME AND I'M SOLVING THESE PROBLEMS HERE.
    210 SUPER AIR RUNS WOT FOR 15 SECONDS OR SO THEN BOGS DOWN, LET REST A FEW SECONDS, AND GOES AGAIN, ONLY TO BOG DOWN AGAIN. 55 PSI AT RAIL THEN DROPS TO BELOW 30 PSI.
    I REPLACE HIGH PRESSURE FUEL PUMP, TEST BOAT FOR SEVERAL MILES. NO PROBLEM THEN IT STARTS AGAIN. WILL TEST FUEL PRESSURE AGAIN ON FRIDAY, ALTHOUGH I'M SURE THE RESULTS WILL BE THE SAME.
    ANY SUGGESTIONS FROM THOSE WITH REAL WORLD EXPERIENCE.
  • JUST-IN-TIME
    • 293
    • ON YOUR BOAT
    RE: fuel pressure/runability issues
    that is normal bro, it is supposed to drop
    down load the manuals and read
    invest in diacom
    sounds like your shop is a parts changer, you do not want to do this
    did the fuel pump have a white or black dot on it?
    invest in the right tools and CERTIFIED TECHS
    HUMAN BUILT = HUMAN FIXED
    switchbait.com
      Cap lock key!
      With driveability issues you need to understand and have accurate info on the fuel pressure. Only the latest engines have the ability to feedback air fuel ratios to the engines computer. In most marine fuel injection engines the computer assumes the fuel pressure is correct.
      • frms1
        • 3
        I'M WITH YOU ON CERTIFIED TECHS. WORKING ON SOFTWARE TRAINING NOW FOR MERCRUISER AND WILL BE SOON FOR PCM.
        MARINE TECHS ARE VERY DIFFICULT TO FIND IN LOUISIANA, ESPECIALLY IN SMALL TOWNS. ANYBODY OUT THERE WANT A JOB IN NEW ROADS, LOUISIANA?
        ANYWAY, FUEL FILTER WAS VERY RESTRICTED. REPLACED AND CURED THE ISSUE.
        • JUST-IN-TIME
          • 293
          • ON YOUR BOAT
          sounded like bad gas or they mixed with e-10
          i might know a guy down there
          i will make a few calls
          well if you sell CC get diacom, it covers them all!!!
          merc is just for merc
          switchbait.com
          • frms1
            • 3
            we're working on getting stocked with the tools and parts inventory. thanks
            • JUST-IN-TIME
              • 293
              • ON YOUR BOAT
              you need the fuel pressure gauge with the bleed off
              diacom with every adapter, CDI has a tool also
              switchbait.com
