Heater Installation
  • leonveefkind
    • Aug 2007
    • 6
    • Netherlands
    Heater Installation
    hi there, i need some help.
    I'm installing a heater in my sn year 2001 gt40 and everything was going well untill i removed the sensor on top of the engine and i tried to put in the "T" piece (forgive me if i 'm using the wrong words )
    I can't turn the "T" piece because there is an obstacle. see arrow in the picture.
    Is there anyone who can help me?
    Greatings
    Léon (netherlands)
  • JUST-IN-TIME
    • 293
    • ON YOUR BOAT
    RE: Heater Installation
    that is the fuel rail
    DO NOT MOVE THAT!!!
    HUMAN BUILT = HUMAN FIXED
    switchbait.com
    • leonveefkind
      • Aug 2007
      • 6
      • Netherlands
      Thanks, i thought so.
      Do you know a solution?
      • ClemsonDave
        • Oct 2004
        • 659
        • Glen Allen, VA
        • Ski Nautique 200
        there are a few places to tap into the cooling system. If you take a picture of the front of the motor (specifically the water pump area), we'll point them out. I believe you can also run one hose to the block. That should be on the side of the block towards the bottom. One side will have a brass plug in it, the other side will have the thermostat.
        Promo Team member
        1999 196
        2010 200 Team 2010 200 Team
        2011 200 Team 2011 200 Team
        2012 200 Team - 2012 200 Team
        2013 200 Team - 2013 200 Team
        2014 200 Team - 2014 200 Team
        2015 200 Team - on the way
        • leonveefkind
          • Aug 2007
          • 6
          • Netherlands
          Problem is solved! Thanks for the reply
          • wake_fun
            • 1330
            • CA
            • 1995 Super Sport
            Check out my heater install pictures. It might help.
            Photo Album
            Ballast Install 1
            Ballast Install 2
            Amp Install
            PPass Install
            Alternator Install
