I recently bought a 1989 Martinique with a PCM 351 and just changed the oil. I did a full oil and filter change. Yet I added 4 1/8 quarts and then ran it and was expecting to add more oil after it flowed through the filter. But even after running it when I checked the oil it actually showed slightly overfilled. Based on my reading it seems like this engine should take around 5 quarts. Why would this engine take so little oil? I touched the oil filter while the engine was running and it was warm to the touch so the oil is circulating. The only thing I can think of is that the dipstick was replaced at one point with the wrong one. Is there any way to make sure I have the right dipstick? Any other ideas of what would cause it to only accept 4 1/8 quarts? By the way it has a quick drain oil kit if that makes a difference. And I made sure that all the old oil was drained before refilling it. Thanks in advance for the help.
-James
-James
