Voltaqe for PCM GT40
  • Gpack
    • Jun 2008
    • 2
    I have a 2000 Ski Nautique with 351 pcm gt40 engine. I am having some gauge problems so I checked my voltage. When the engine is not running I am at the normal 12v but when the engine is in operation the volts I get at the battery and the alternator is 30.7v. Is this normal or do I have a problem with the voltage regulator?
    Thanks in advance for the help
  • wtrskii3156
    • May 2006
    • 39
    • Virginia
    RE: Voltaqe for PCM GT40
    are you sure its 30.7 v?! it should be at about 14.5 with the boat running.
    • AirTool
      • Sep 2007
      • 4049
      • Katy, Texas
      I don't see how it could be 30 even if the regulator pegged out.
      Maybe you meant to type 13.7
      I think the spec is 13.6 to 14.4 ...but that is from memory....should be close though.
      AirTool
      • Mikeski
        • 2908
        • San Francisco, CA
        Is you voltmeter set to DC?
        • Gpack
          • Jun 2008
          • 2
          Voltage set to DC
          I had realized i had my volt meter set to AC and made the change as someone suggeted. I am still getting a reading that is 15.6v so I had the alternator bench tested and it was the same. Is this too high? The volt meter on the dash is pegged at 16.
