Hi guys hope you dont mind me crashing your forum, but I have a PCM ZR6 problem.
First time out this year I lost the CK sensor I replaced it and had the DTC's cleared. Ever since then my motor has not ran right. at an idle it seems to be a little rough and under load it will not go past about 2k rpm. I can smell gas and it seems to be loading up.
When I took it to my dealer they said I had 2 bad injectors after a power balance test. Well I replaced the injectors and that did not cure the problem. At one point the told me my TP sensor was bad but testing it using DVM there was no problem with it but Diacom software could not see it. I was wondering if my ECM could have shorted when my CK sensor went bad and now I am running on defaults?
Any thoughts
Any thoughts
. Problem is fixed I am certain he appreciates all the help. And speaking for him and I we hope you don't mind us being on your boards and forums their is a great wealth of knowledge here.
