Arrrrrrggghhh won't turn over
  • Critter
    • Jun 2008
    • 1
    Hi All,
    I have a 2002 Super Air, and am about to pull what little hair I have left out... Here's the deal: I get power to the ignition, can run all acc. but as soon as I hit the start button, all I get is a click and the power to the ignition goes off. Have checked for possible low battery, have checked the kill switch (bypassed it) with all power to the systems I don't know what to check next.
    We live in a fairly remote area with the nearest dealer several hundred miles away.
    Here I kneel in a begging position half near to tears. Please Obi Wan, you are the only one who can help.
    thanks in advance...
  • jward
    • Feb 2008
    • 620
    • Sweet Home Alabama
    • 03 SANTE 04 SANTE
    RE: Arrrrrrggghhh won
    check fuses! You have the 330 right? Check the red 60 fuse on the motor. the best thing to do is start at the battery with a volt meter and follow along until you find where you are not getting power. Good Luck
    • brianc
      • Dec 2004
      • 46
      • Europe
      • 1999 196 2005 196 team zr6 2005 226 team zr6 2007 211 team zr6 2006 196 excal 2008 196 limited z409 2010 200 team ob 343
      look at the silver three poition swith if you have one fitted if not you may have a bad ground somewhere possably on starter
        Clean the battery terminals.
        • core-rider
          • 1350
          • Huntsville, AL
          • 2003 Black SANTE
          I know this is gonna sound real redneck and crude, but try hitting the starter with a hammer or something similar while someone else tries to start the engine. If it tries to turn over then, pull the starter and have it rebuilt.
          A friend of mine just had the same thing happen to his '03. Starter solenoid was sticking so most of the time all he got was a click. This happened the first time he tried taking it out after sitting up all winter.
          Jason
          All black 2003 SANTE
          -- Southern Fried --
          • TRBenj
            • 1681
            • NWCT
            Agreed. Clean every single battery cable connection, both positive and ground, from the battery to the block (-) and starter (+). Also have your battery load tested.
            What youre describing is the classic low-voltage condition- and dirty cables and bad batteries are the most common culprits.
            1990 Ski Nautique
            NWCT
            • 2gofaster
              • 671
              Yep, just went through this. Same symptoms. Replaced the battery cable ends and cleaned the battery terminals and all is good again.
              Shane Hill
              2014 Team 200OB
              67 '13 Prophecy
              • tim.muench
                • Oct 2005
                • 11
                Just had same problem - Shifter wasn't exactly in neutral
                Check to make sure it's exactly in neutral. I was JUST slightly out of neutral, and finally I realized it and just bumped it into neutral, and away it went.
                • bkhallpass
                  • 1407
                  • Discovery Bay, CA
                  RE: Just had same problem - Shifter wasn
                  Core-rider, doesn't sound redneck at all. Done it many times on a Chevy. However, it's not the problem.
                  It's not the kill switch or the neutral throttle either, because those wouldn't shut down the power.
                  As Tim said have the battery load tested. Had the same issue on my 01 just two months ago.
                  Replaced battery and cleaned terminals and all is well.
                  2001 Super Air
                  • JUST-IN-TIME
                    • 293
                    • ON YOUR BOAT
                    it is the ground wire or bad battery
                    HUMAN BUILT = HUMAN FIXED
                    switchbait.com
                    • linebacker55
                      • Mar 2007
                      • 44
                      • Goose Creek, SC
                      I had a similar problem, kept blowing fuse when i hit the start button, turned out to be the low pressure fuel pump was shorted and drawing too much current. Just a thought...I was pulling my hair out for about a week trying to figure that one out. Good Luck!!
                      2002 Super Air Nautique
                      • kadymiller
                        • Feb 2006
                        • 1
                        What was the fix? I have the same issue on my 2001 Super Air Nautique. Accessories work but the power drops out when I press the start button. Was it a battery load issue?
                        • windsurfnut
                          • Mar 2018
                          • 69
                          • Ontario
                          • 2002 Ski Nautique
                          Chased this last year on a 2002 SN196. It was somewhat intermittent, as it would do it one time and not the next. Cut and re-terminated battery connection, looked for bad grounds, battery appeared to be fine and charge up.. Finally gave up and put a new battery in it and never had an issue again. Battery was going bad but would start the boat some of the time.
