Drive shaft key worn out
  • icewake
    • Jun 2004
    • 42
    • Canada
    Last night I found out that I had to replace the key that is located between the engine coupler and the drive shaft. :cry:
    I am good with doing mechanic stuff myself, but since I bought my boat used and it didn't come with a Owners Manual, and I never did this before, I really don't know what to do.
    the specs of the boat:
    1999 CC 196ob Ski Nautique with pcm gt40 efi
    1- how do I remove and replace the shaft ?
    2- is there things I should check while I have the shaft in my hands?
    3- should I be changing any other parts while I am doing this?
    4- what parts should I order before starting the work?
    5- is there special tools I need?
    6- can someone help me get a maintenance manual to do this (I need specs for thightening )?
    7- how long should this process take?
    I look forward to your answers and help
  • tryan
    • Nov 2003
    • 267
    • gatlinburg tn
    elberts.com will walk you thru the process. i would go for a new strut bushing and some fresh packing, but you should be able to tighten the shaft without removing it completley.
    red right return
    • icewake
      • Jun 2004
      • 42
      • Canada
      tryan, I am glad you answered my post, I've noticed by your many answers on this board that you really seem to know what you are doing.
      So I will go to that url and go from there!
      thank you so much.
