Which wires go where on coil?
  • uncle-buck
    • Jun 2004
    • 29
    • Houston, TX
    I am replacing the coil on my 1990 Nautique which has a PCM/Ford 351 engine. Polarity is indicated on the new coil, but not the old one. Which wires go on the Positive(+) side of the coil, and which wires go on the Negative(-) side? Thanks in advance.
    \"Helping you make smart choices about your money - so you can live a better life.\"
  • tryan
    • Nov 2003
    • 267
    • gatlinburg tn
    the negative post on the coil is generally hooked to the points and the tach feed. the positive terminal is generaly hooked to ballast resistor. if you have the pro-tech, repost.
    coil are a tough thing to kill. are you wired thru a ballast?
    red right return
    • uncle-buck
      • Jun 2004
      • 29
      • Houston, TX
      Thanks. Yes, it is wired through a ballast.
      • nms1991
        • 477
        the purple wireas go to the positive side and the black wire and grey wires go to the negative side.
        • EchoLodge
          • Jan 2004
          • 616
          • Huntington Beach, CA
          • 99 Super Sport
          Coil
          I just replaced my coil this weekend and can confirm... purple positive and gray negative. This is my boats third coil. It has 860 hours. I always thought coils were bullet proof. But second my boat feels like it is missing under load and at high rpms. A $20 coil has always fixed the problem.
          sigpic
