Base rumble in the boat...not the woofer
  • cuda1
    • Jun 2008
    • 7
    I just purchased a '98 SN. There is a low frequency base hum at idle. The floor will vibrate when idyling forward. To me, it gets a bit load at mid speed, resembling the low frequency base of a stereo. Any thoughts??
  • Andrew
    • Aug 2005
    • 891
    • Tuscaloosa, AL
    RE: Base rumble in the boat...not the woofer
    i think you need to check your drive shaft alignment....
    • cuda1
      • Jun 2008
      • 7
      Thanks Andrew,
      I am scheduled for an alignment. However, this morning I noted this frequency pitch when we were not under power but sitting in neutral at idle. I thought shaft movement is stopped while sitting with motor idyling.
      Thanks again.
      • Andrew
        • Aug 2005
        • 891
        • Tuscaloosa, AL
        sometimes the shaft will still turn due to the inertia of the tranny fluid, but it shouldn't be enough to create a noise or vibration.....
        • cuda1
          • Jun 2008
          • 7
          This is what I would think. So, it may simply be the boat. It's something I don't recall when riding in others. I describe it as a base sound that oscillates slightly and causing some vibration in the floor. Maybe I'll get used to it.
