We just purchased a 2008 210 Signature Edition (Base Model Boat). It has the Nautique Cruise speed control which is worthless. Does anybody know if Zero Off can be added to a signature edition? If not, does anybody have any suggestions? Thanks.
Tags: None
RE: Adding Zero Off to an 08
As long as it has a T.B .W ( I think all of them do) you can add it. You can also put a prefect pass on it. I have had both and love the zero off in my 2302016 G23 H6
2014 G23 550
2013 G23 450 (Great boat)
2000 SAN ( Loved that boat)
ZO can certainly be added to that boat. Should be pretty much plug-and-play.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Zero Off
What options are avaiable for 2004 206 Air Team? I have wakeboard pro. Is there an GPS based system that would work?
If it is WB Pro 6.5 ng, it's about $400 to upgrade. If it's an earlier version, add $199 for a multiline display.1998 Ski Nautique (Red/Silver Cloud), GT-40, Perfect Pass Stargazer 8.0z (Zbox), Acme #422, Tunable Rudder.
Re: RE: Adding Zero Off to an 08
Originally posted by LaketexomaAs long as it has a T.B .W ( I think all of them do) you can add it. You can also put a prefect pass on it. I have had both and love the zero off in my 230
Originally posted by OHLNautiqueOriginally posted by LaketexomaAs long as it has a T.B .W ( I think all of them do) you can add it. You can also put a prefect pass on it. I have had both and love the zero off in my 2302001 Air Nautique
RE: Re: RE: Adding Zero Off to an 08
Not to change the subject, but, does anyone know if the throttle by wire can be adjusted? After I move the boat into gear the throttle has to travel a lot before I get any response.
For anyone interested. I talked to Correct Craft today and the Zero Off is simply plug and play in a signature edition boat. Thanks for the advice.
