Problem with Perfect Pass
  • pablo
    • Jun 2008
    • 30
    The other day out I noticed that the Speedometer and perfect pass arent working. Pulled the boat out and noticed the The two flaps on the side of the paddlewheel where bent in toward the paddlewheel. I moved them back to their original position. Next time out it would register speed but it wasnt correct. It woud show that i was going about 11mph when i was really going about 22mph at 3000 RPM. Any idea what the issue might be? I also thought that the Speedometer would have run separately but apparently not. The Paddlewheel looks fine. I was surprised how close it is to sitting on the bunk when on the trailer, if the boat is pulled up too far on the trailer it will sit directly on the bunk and bend it which i think probably happened in the first place.
