I THINK it is the ACME 1234 (or 1235 if a LH prop)? There is a post in reviews on props you can check out. Hopefully others will help confirm or offer better advice.
The 1234 wont fit an '04. The 1464 is the prop you want for power. I read here somewhere that it's a modified 1234 made to fit the older SAN's. At wakeboarding speeds (21-22) your rpms are around 3300-3400. Top speed is around 36mph, but thats pushing over 5000 rpms. Safe cruising speed is more around 30 mph. I run with about 2000lbs of total ballast (people not included) and the boat planes quickly with 3/4 throttle.
The 1464 would be way differant than a 1234 if those numbers are true. My 1234 will top out @ 43/5000rpm. But I agree that the 1234/5 will not work on the older 210s. What're the dimensions on the 1464?
13.50 diameter 14.50 pitch .105 cup. The top speed might be closer to 38-39, but I have never tached it out past 5000 rpm's for more than a couple of seconds.
