we have a 82 nautique, we had the boogered up prop refurbished and the guy also suggested doing the strut bushing too.
The shaft is out so thats not any issue.
heres the deal. the strut has 2 2 in. long bushings in the ends. the bushing that the guy at the prop service place gave me a 4 in long bushing. should i cut the 4 in long one to make 2 2 in long ones or just put in the 4 in. long one as is. also if i just use the 4 in. as is, should it go dead center. in the front or in the back?
i've dont some searching and didnt really find what i was looking for.
also, i'm going to put the bushing in the freezer right now.
if it is recommended to cut the bushing in half. will it hurt to do it after i take it out of the freezer in the morning?
IF i do cut it i assume the correct thing to do is use a tubing cutter and cut the bushing in half with our old warped shaft in the bushing? correct. any advice or other hints please speak up.
thanks guys.
thanks guys.
