I have a 98 sport Nautique, when I started it yesterday I noticed a pinhole water leak in the fiberglass riser from the engine to the water discharge. This is on the drivers side of the boat. Any idea how to fix.....or does it need to be replaced?
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
RE: pinhole leak on fiberglass riser from engine to rear wat
Are you talking about the exhaust risers? Is it at the gasket point? If so, just replace the gasket. Do it soon as that leak can cause major problems if it gets too bad. Entire risers can also be replaced. Was the boat ever used in salt water?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I think that he is talking about the muffler? Just use glass and resin to patch it.2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
Many upgrades coming...
Re: RE: pinhole leak on fiberglass riser from engine to rear
Originally posted by Randy.BrodbeckI bleieve they are the exhaust raisers. It is after the gasget on the approx 4" round fiberglass riser. Can I put additional fiberglass and resin over the top of the current fiberglass?
