Some more comments:
1. Other tricks to catch oil filter spillage is to cut down 1 liter or 2 liter soda bottles depending on filter size. Cut the top off for a disposable bucket or cut the bottom off for a disposable funnel.
2. I 've seen pictures of some of the ford engines with the tilted filter adapter...what a mess.
3. I prefer draining hot rather than sucking out hot. Draining hot gets more of the crud out. Sucking cold is doable but almost impossible. I sucked some 7 year old oil out of a 5.0 mercruiser one time. My vacuum pump and my home-made mason jar oil bong were operating at about 20" mercury vacuum. I can only imagine the mess if the jar had imploded. As soon as I got most of the old oil out, I put fresh oil in, ran it on the hose until it was hot and did it again. Then put new oil and ran it on the lake for half a day then did it again...so far so good. Brother-in-law's boat...still going. He probably hasn't changed the oil since then.
4. I like the overnight drain also. I save my 5qt oil bottle from the last change and let the oil dump out hot. While it starts, I do the filter. Come back the next day and check the volume that drained. I prime the filter plus start by pouring in the same volume that drained out. So far, spot on each time.
AirTool
AirTool
