I have the GT-40 motor in my '98 sport nautique. When the engine gets to 2500 rpm and above it starts to cut in and out like it is not getting enough fuel. The check engine light is constantly on. The engine never completely shuts of but will rev up and down at any rpm above 2500. Below 2500 the engine runs normal. I also have to put it in neutral and give it a little gas to crank, which i did not have to before. The engine will not run at idle, only when a little throttle is applied (approx 900-1100 rpm).
I replaced the fuel filter thinking that was the problem. Needless to say it did not remedy my problem. Spark plugs and injectors are also good. My fuel pressure stays steady at 35-40 psi and does not change when the engine starts to go in and out. This problem began all of the sudden after about 3 hours of run time one day.
Any and all help or suggestions are much appreciated. Thanks ahead of time for your help.
