Ok, yesterday my friend and I took the boat out for about an hour, just driveling around at idle speed. The boat was fine, but then when my friend went wakeskating first weird thing was that for no reason the throttle burped (meaning that the throttle cut out, but then came back) that was the first weird thing that the boat has never done. Now the stalling issue happens at idle speed (and only at idle speed) you put the boat barely in gear and the boat will die, but she has no problem with running at any speed above and idle speed the boat also can idle fine. (Idle speed is actually slower than the idle) All engine vitals are perfect, I'm suspecting that it might be a bad fuel pump? Fuel filter? The boat had been sitting for about 3 weeks with 3/4 of a tank. (Bad fuel?) But if it is bad fuel then why did it run for about 2 hrs perfect then start doing this funky deal?
Sorry about my typing, I'm writing this on a really s*itty monitor and a Pentium I at 200 MHZ.
