My boat will run for several hours with many stops and starts of the engine, when suddenly it won't start again. I've checked spark and I've got it...so I figure it's a fuel problem. On the top of the engine ( PCM pro boss GT-40), there's a shrader valve in the fuel line. While I've never checked the pressue with a gauge, I have pressed on the valve while cranking the engine and get air coming out long before fuel comes. From there it'll occasionally start, but most of the time it doesn't. That's when I pound my head off of things and cry like a child. When I return to the boat the next day I get the same thing...runs great..then nothing.
I've been told the diaphram in the fuel pump may be cracked and I'm getting air on the line as a result. I'm planning on purchasing a new fuel pump but need info, please. Is the fuel pump on this motor easy to find? anything special? Also I've never changed a fuel pump. Will I need to completely drain the tank to change it out?
Thanks for your time.
Scott
Scott
