Hello All -
Boat is a 2000 SAN.
Was out last Wed evening and had water pumps running from both 12v plugs in the boat. They both suddenly shut down so I figure a popped fuse. I also have lost the stereo, horn and air/water temp guage.
I check the fuses back at the positive lead to the battery - both good. Check the ACC and HORN fuse (which are side by side) in fuse panel under the dash. Neither are popped so I pulled the ACC fuse to check it - working properly. I pulled the dash off thinking there was maybe something back there gone bad - nothing I can see. Pulled the stereo head unit - all looks OK there.
The boat does have an aftermarket amp, sub and tower speakers (no power to the amp also) that were installed by the dealer back in 2001 or 02.
Everything else in the boat works great, as usual, so we are able to ride but with no tunes or way to fill the fac-sacs...
So any thoughts on where to look next? I'm hoping its something real simple I am missing.
Thanks much for any help.
John
Boat is a 2000 SAN.
John
