I'm having serious issues with my 1998 Air Nautique. It has the following symptoms:
1. It sometimes (not always) takes a good minute of cranking before it will turn over.
2. Once started, it idles at very low rpms (400 or so), and then ends up dying if I don't continue to rev it in neutral.
3. When I rev it, un-used gas ends up coming out the exhaust into the water.
4. It has very little power out of the hull, but then it gets going and does fine at high speeds.
My mechanic looked at it and thought it had water in the gas, but I've replaced the fuel seperator and even emptied it several times. I'm thinking I have issues with the carburetor. Any thoughts on what I need to do?
