gauges/oil/water/noise
  • fitzee
    • Feb 2008
    • 127
    1. how do i get the gauge lights to come on in 06 210 team i hit the nav light button and the only thing that comes on is the ballast gauge lights and nav lights is there even lights in the gauges on the dash and is there a fuse that might be gone
    2. when i hit the stop button and the motor is stopped the message on the gauge says low oil is that normal and i checked the oil and it is perfect it only happens when i shut the motor off
    3. is it normal to have quite a bit of water drain out after riding
    4.first ride out tonight in the new boat and i took off and it ran fine but then it started to act up making a weird noise but i ajuste the perfect pass when i was moving and it was on when i took off is there a warm up lock out or someone ever have this happen
    thanks :shock: boat is 2006 210 team
    2006 Super Air 210 Team Edition(SOLD)
    1995 MB Sports boss 200 (SOLD)
  • Quinner
    • 2246
    • Correct Crafts
    RE: gauges/oil/water/noise
    1. The dash gauge lights will only come on if the ignition is on. If ignition is on and still no lights check your connections at the faria gateway box.
    2. Once you stop or turn off the ignition those displays should go blank?
    3. Drain out of where? If the bilge, no. A little is ok and may be expected if you do not have a drip-less packing otherwise unless your skiers/riders are coming in soaking wet and draining into the boat you really should not be taking on much if any water.
    4. If you engage the PP while underway it may alarm for a while, try to turn on/off while in neutral whenever possible.
    • mjmaatman
      • Oct 2006
      • 35
      • Clarksville, MI
      • 2006 SV211
      2. I have an 06 SV211. The low oil pressure light comes on when I stop the engine. The dealer said the sensor reads oil pressure quickly after turning off the engine so you get a brief low oil pressure warning because there is no pressure when the engine is off (obviously). Sometimes it does it sometimes it doesn't. Stopped worrying about it after the dealer said it was typical.
      4. Never had a problem with engaging the PP while underway since the engine is DBW, so not sure what is causing the noise.
