Had boat out the other day ran great, got home cleaned boat and flushed engine on water hose and again ran great on water hose, then put boat up. Went to take it out this weekend and there is no power to the dash. Checked battery its good checked power switch next to drivers seat and it has power going to it and there is no blown fuses. I unplugged my ignition keypad and i have power going to the wireing harness but it doesnt work. will a bad ignition keypad cause everything else not to work. Any help would be great thanks
RE: 2002 super air lost all electrical power
my 00 did this and it was an inline fuse holder back by the battery. it is a cylinder with a glass fuse in it. we were hitting double ups and the boat would go dead because it was rattling loose check for that and if it is melting down like mine was replace it with a card style auto fuse holder. it fixed my problem when i thought it was the key pad too. This may be different for 02 though good luck. This cost about 4 bucks to fix as opposed to 400 or so for the keypad00 SAN 210 (previous boat)
07 236 te sold
