Diameter of Pylon on 1986 Nautique 2001
  • wepucci
    • Jul 2008
    • 15
    I'm trying to purchase a pylon clamp for a boom for my 1986 Ski Nautique 2001. The closest I can measure the diameter to is 2-1/2". According to the manufacturer of the clamp (Skylon Sports), the sizes they have available area 2.48”, 2.52” & 2.56” (i.e. more accurate than I can measure). Does anyone know what the diameter of the standard boom on a 1986 nautique is? It is the one with the ring and the finger. Thanks.
  • Hollywood
    • Sep 2003
    • 1930
    • WIIL
    RE: Diameter of Pylon on 1986 Nautique 2001
    Your pylon is 2.5", the ECI clamp is adjustable so I'm not even sure where you're pulling those numbers from.
    • wepucci
      • Jul 2008
      • 15
      Thanks for the reply. The numbers came straight from Paul Ceballos guy at Skylon. The following is the text from an email I received from him after I sent him a PDF file with an existing clamp I was trying to match (I've also attached the PDF file) :
      -----Original Message-----
      From: Paul Ceballos [mailtoaul_eric@skylonsports.com]
      Sent: Friday, August 08, 2008 4:51 PM
      To: 'William E. Pucci'
      Subject: RE:
      Bill,
      That does not look like our clamp.
      Our boom clamps come in 3 different sizes:
      2.48”
      2.52”
      2.56”
      Verify that your boom in manufactured by Skylon. If it is, also verify your pylon diameter with the boat manufacturer.
      • Hollywood
        • Sep 2003
        • 1930
        • WIIL
        Ok, but what exactly do those sizes mean? Maybe he's not talking about pylon diameter...
        • harddock
          • Apr 2008
          • 292
          • toontown E-9
          I bought a Skylon boom several years ago and got it with an adjustable pylon mount that fits my 87. I was more concerned that the boom had only one cable going to the bow when all others I see use two. This one even had provision for a second cable but it was a slight chore to install at home.
          • wepucci
            • Jul 2008
            • 15
            I was told that the 2.48”, 2.52” & 2.56” dimensions are for the "inner bore" of the pylon clamp.
            • wepucci
              • Jul 2008
              • 15
              Clarification - the dimensions are for the DIAMETER of the "inner bore" of the pylon clamp.
              • Hollywood
                • Sep 2003
                • 1930
                • WIIL
                So then go with the 2.48", the other two will be loose.
                If your boom is supposed to have 2 cables you better be using 2. The Bemman's are designed with one cable but it is larger (stronger).
