how do i check fuel level and volts with out starting boat on a 06 210 keypad :???:
RE: gauges
you should be able to just hit start once after entering the code. just press and release once, and the gauges should "start up" in a couple seconds, without the engine turning over.How 'bout a little reverse action...
RE: gauges
I believe you need to push the button a second time as if to start but dont keep it depressed as if starting.2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
