This is on a 99 sport nautique with the GT40 and the pp says “cruse control by perfect pass” (I think it is RMP based, no paddle wheel).
I took the boat out to the lake last weekend and everything was fine for about 4 hours. Then I noticed that there seemed to be more play in the throttle, like the neutral area was growing. I didn’t think much of it at first, but it was getting worse. A few min later the boat would not go into drive until almost full throttle. The same thing happens in neutral, idle until about 80% power than the motor will rev. max rpm is about 2k in drive or neutral.
At fist I was thinking it was a throttle cable, but when the motor does rev it is smooth, not what would think of a sticking cable. This boat is new to me, and I think it is a problem with perfect pass. The light was flashing, but I could not get the system to disengage (I tried holding both buttons for different amounts of time up to about 30 sec).
When I opened the motor cover there was slack in the pp actuator and the knob was moving back and fourth about 15 degrees. At this point I am thinking it is either an adjustment or a problem with pp. if anyone has any info it would be greatly appreciated.
