No Oil Pressure??
  • seth
    • Jun 2008
    • 549
    • Santa Barbara, CA
    • 01 SAN-sold
    No Oil Pressure??
    I looked down at my gauges the other day while pulling a rider and noticed my oil pressure gauge was reading 0. I immediately stopped and idled back in, luckily I was close to the ramp. The engine never sounded different and seemed to be running normal (im not sure how long it was reading 0). Im wondering if my gauge is bad or has a short? If there was no oil pressure would I be able to tell right away? Any input is appreciated.
  • jward
    • Feb 2008
    • 620
    • Sweet Home Alabama
    • 03 SANTE 04 SANTE
    RE: No Oil Pressure??
    Have you checked the oil level since then
    • mike196
      • Mar 2004
      • 12
      • Deep Creek Lake, Maryland
      The engine would sound different for sure if you had no oil pressure. I just experienced this with my other inboard boat - an older Supra Beast - not my Nautique. As it turns I had installed the wrong type of oil filter. After about 30 hours or so with that filter I started the boat one morning and it immediately started making loud knocking and pinging sounds near the top of all 8 cylinders. You could just hear something wasn't right. If your engine sounds normal it may be something as simple as the gauge.
      • AirTool
        • 4049
        • Katy, Texas
        IMO ....if you made it back to the dock....you have oil pressure.
        AirTool
        • KTompkins
          • Aug 2004
          • 34
          • Corpus Christi, TX
          • Current boat: 2009 210 SANTE Second boat: 1995 Sport Nautique First boat: 1982 2001
          Check for a loose wire on the back of the gauge. I had that problem. Surely your engine would go into safe mode and alarms would go off if you lost oil pressure.
          What year is your boat?
          Old Boat: 1982 2001
          Old Boat: 1995 Sport Nautique
          New Boat: 2009 SANTE 210
          • seth
            • Jun 2008
            • 549
            • Santa Barbara, CA
            • 01 SAN-sold
            It is an 01 SAN, and as soon as I saw the gauge I turned it off and checked the oil. The oil level was fine, I have since changed the oil and filter. When I tried to remove my dash to check wires I stripped out one of the allen bolts trying to remove my steering wheel, and havent been able to check them. Thanks for the input, im thinking (and hoping) its my gauge as well.
            • Stunts
              • 16
              I just had my boat in for service and they noticed my oil pressure guage was showing 0 too when the engine was running. I had no idea how long it had been showing 0. They replaced the entire guage.
              • AirTool
                • 4049
                • Katy, Texas
                Re: RE: No Oil Pressure??
                Was it the gauge or sender? I know you said gauge...but...just checking.
                AirTool
                • 2gofaster
                  • 671
                  RE: Re: RE: No Oil Pressure??
                  Senders are notoriously iffy. That's what I always replace first. Usually that fixes it.
                  Shane Hill
                  2014 Team 200OB
                  67 '13 Prophecy
                    You can pry the plastic cap on the center of the steering wheel, and then you will see a 3/4 nut in the center. Remove the nut, mark the steering wheel position on the shaft, and you can pull the steering wheel without removing the six Allen screws. Glue the cap back on with an RTV sealant. (Silicone Seal)
                    I believe that all the motors that were available, had additional sensors that would turn on red lights, and at least put the motor into a limp mode if you truly had no oil pressure.
