Greasing Roller
  • mf01
    • Jun 2005
    • 515
    • Austin, TX
    Greasing Roller
    I have a roller that seems to be stuck/sticking. In my driveway it wouldn't move at all. I put some WD40 on it and after a few hours I could barely get it to move. I was thinking about using some type of grease to actual lube it, but I'm not sure where to grease it. Here's a pic:
    Previous:
    2011 Super Air Nautique 210
    1994 Sport Nautique
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Greasing Roller
    Its probably corroded past the point of lubing. West Marine sells them for about 20 bucks You may have to cut the old one off. Then lube the new one with marine grease.
    Nautiqueless in San Diego
    • mf01
      • Jun 2005
      • 515
      • Austin, TX
      RE: Greasing Roller
      How do you typically get these out? The end cap would not budge with a flat head.
      Previous:
      1994 Sport Nautique
      • Rick
        • Mar 2004
        • 1250
        • San Diego, Ca
        RE: Greasing Roller
        If it is that corroded a hacksaw or cutting wheel may be required You just have to replace the bolt as well.
          RE: Greasing Roller
          The bolt might be bent. That puts the roller in a bind, and makes it hard to turn.
          • Hollywood
            • Sep 2003
            • 1930
            • WIIL
            RE: Greasing Roller
            there is no need for a roller on a ski boat trailer
            • mf01
              • Jun 2005
              • 515
              • Austin, TX
              RE: Greasing Roller
              I fight the roller when putting the boat on the trailer. The only way to stop that would be to put the truck deeper in the water. I launch at a steep ramp, so my back tires are in the water when I load the boat. With them in the water I still rub on the roller.
              Previous:
              1994 Sport Nautique
