Starting problem - (Battery was installed backwards)
  • markdief
    • Jul 2004
    • 20
    • PA
    I'm the guy that accidentally hooked battery up backwards. I reset circuit breaker switch on engine. All switches seem to work just fine EXCEPT when I try to start boat with key everything cuts out. I can get myself back to the previous state only by unhooking battery and then rehooking it up. Any further suggestions / guesses would be appreciated.
  • jward
    • Feb 2008
    • 620
    • Sweet Home Alabama
    • 03 SANTE 04 SANTE
    RE: Starting problem - (Battery was installed backwards)
    does the battery have full charge on it.
    • markdief
      • Jul 2004
      • 20
      • PA
      Sure seems to. Blower runs real strong, etc.
      • M3Fan
        • 1034
        What year is the boat? The newer boats with keypads, etc. really don't like it when you reverse the polarity like that.
        2000 Ski Nautique GT-40
        2016 SN 200 H5
        www.Fifteenoff.com
        • Hollywood
          • Sep 2003
          • 1930
          • WIIL
          It couldn't hurt to charge the battery and try again.
          • markdief
            • Jul 2004
            • 20
            • PA
            It's a 1990. I had recharged the battery (charger shows full charge). I'm actually going to buy a new battery this weekend just to take this out of the mix.
            Didn't know if ignition switch itself is the issue at this point.
            • jward
              • Feb 2008
              • 620
              • 03 SANTE 04 SANTE
              Kill switch could be bad
              • markdief
                • Jul 2004
                • 20
                • PA
                it's working now
                Not sure why it's working now but I'll take it. I came home from work, reattached battery and it started right up. I hadn't recharged battery again or anything like that. Thanks to everyone for help. I'm sure I'll do more dumb things but certainly not be careless hooking battery up again.
                • i_am_am
                  • Mar 2007
                  • 43
                  • randleman,nc
                  • 1978 Correct Craft American Skier- 1st boat owned for 25 yrs Now have a 1999 Super Air that was bought trashed. Rebuilt the engine, steering, ballast, just anything exposed to salt water was replaced.
                  RE: it
                  you might want to check the alternator while running to make sure it's charging. they don't like reverse hookup either.
                  78 CC Amer skier(25yrs)
                  >>99 SAN gt40<<
