I was wondering if anyone could help me. My 3 year stuck a screw from the bimini into the 12 volt outlet which shut down/killed the boat while we were driving. I tried to reset the 60 amp breaker at the back of the engine and it did not do anything. Any suggestions?
RE: gt 40 DEAD
Check both battery cables at the battery.
Check the fuse in your battery box.
Check for power on a red, purple wire going to your key.
There might be a fuse in the power lead going to your key
Check for power at the cube relays, pin 30, both relays.
What year and model of boat?
Do you have a keyed ignition switch, or a touchpad system
