water leak between hull and prop shaft
  • guyhawk
    • Feb 2008
    • 28
    (08 220) After i trailer boat home i use the fresh water flush with the pressure reducer supplied by cc and today noticed a lot of water coming out of the same fitting that the prop shaft exits the hull through is this right or is there a problem, it has the zr6
    thanks
  • whataboat
    • Jan 2005
    • 34
    Thats normal, you have the dripless packing gland fitted, it uses cooling water from the raw water side of the cooling system to lube the shaft at the entry point of the hull.
    • guyhawk
      • Feb 2008
      • 28
      Thanks whataboat, forgot to mention dripless packing gland, have a lake bookd for 3 days from tomorrow, massive relief so thanks a million i can sleep well tonight
      • AirTool
        • 4049
        • Katy, Texas
        I guess it's not dripless then....it just drips out of the boat instead of into the boat.
        AirTool
        • whataboat
          • Jan 2005
          • 34
          no problem, what lake do you rent ?
          • guyhawk
            • Feb 2008
            • 28
            The is in cirencester,England £80 a day for the whole lake.
            • guyhawk
              • Feb 2008
              • 28
              The lake is in cirencester,England £80 a day for the whole lake.
              • whataboat
                • Jan 2005
                • 34
                I know the one you mean, back end of Ashton Keeynes. Also another one that you can rent in Lechlade, I believe it is a bit bigger.
                • guyhawk
                  • Feb 2008
                  • 28
                  do you have an address or phone number for the one in lechlade?
                  • b2
                    • Aug 2004
                    • 61
                    • Fairford, Gloucestershire. UK
                    I will get them for you during the week and send you a PM, provided I get an invite to come surfing if you go there. Yellow_Flash_Colorz:
                    • guyhawk
                      • Feb 2008
                      • 28
                      sounds like a fair swap to me.
