Winterizing - drain, fill or both?
  • bwana50
    • Jan 2008
    • 69
    • Topeka, KS
    There seems to be three schools of thought on winterizing boat engines. I'm curious to see what the consensus is here.
    Do you:
    a) Drain the water and leave the block dry?
    b) Fill the system with antifreeze?
    c) Drain water, then fill with antifreeze?
    1996 Ski Nautique
  • slob02
    • Sep 2003
    • 333
    RE: Winterizing - drain, fill or both?
    Drain...........blow out heater with low pressure air.............then fill.
    2008 Super Air 210 Team
    2004 AIR 206 Team
    1997 Ski Nautique 196
    1993 Ski Nautique SNOB
    • MNSuperAir
      • Sep 2005
      • 591
      • St Paul
      • 2016 SAN 210
      Drain and fill here.
      2016 SAN 210
      2006 SANTE sold
      2001 SAN - sold
      1991 Sport Nautique - sold
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        Drain, purge heater, then fill.
        I had never drained before last year. 12 years and no problems. Draining gives you that last little bit of comfort when it gets to -25* a few nights a year.....
        the WakeSlayer
        1968 Correct Craft Mustang
        • 8122pbrainard
          • Jul 2007
          • 255
          Drain and fill - RV antifreeze
          • TravisFling
            • Mar 2008
            • 889
            • London, Ohio
            • 1989 Ski Nautique 2001
            Drain and fill with RV Antifreeze here too. It tends to get a little chilly on the great plains of the midwest...
            Travis Fling
            Choctaw Lake
            • M3Fan
              • 1034
              Drain and fill, but just draining is fine too. I've done it both ways. Definitely blow out the heater and pump some AF through the shower if applicable.
              2000 Ski Nautique GT-40
              2016 SN 200 H5
              www.Fifteenoff.com
              • Chris4x4Gill2
                • Jul 2008
                • 406
                • Smith Lake, AL
                • '89 Ski Nautique 2001
                whats the proper way to fill with antifreeze? do you just unhook the water inlet hose and pour it in? or bump the motor over a time or two?
                • 8122pbrainard
                  • Jul 2007
                  • 255
                  Re: RE: Winterizing - drain, fill or both?
                  Disconnect one of the hoses from the T stat housing to the exhaust manifold and pout it in there. It will make it's way down into the block. via the engine water pump ports from the block.
                  Besides the block, pump and manifold drains, don't forget to diconnect the hose off the bottom of the oil cooler.
                  There's a real nice pictorial thread in the common questions forum over on CCfan.
                  Tim's (TRbenj) thread on winterizing: http://www.correctcraftfan.com/forum...=8368&amp;PN=2
                  • east tx skier
                    • 1561
                    • Tyler, TX
                    I used to just drain, but with my new to me Nautique, I've gone to drain and fill for any corrosion protection that might provide.
                    In addition to what has already been mentioned, if you're inclined to just leave the impeller in over the winter and replace it in the spring (just in case you get that freak warm day where you drag the boat out mid winter), make sure you pull the kill switch and spin the engine over for a second or three after you drain, but before you fill with antifreeze to kick any water out of the pump housing that gravity might not have taken care of.
                    • Chris4x4Gill2
                      • Jul 2008
                      • 406
                      • Smith Lake, AL
                      thanks for the link. I'll have to bookmark that one and look at it later when I can view the pics
                      • igkya
                        • Oct 2003
                        • 229
                        • Minden, NV
                        • Club boat 2005 196
                        I had a 90 SN and for 14 years, all I did was drain it (no heater). Now, with a 2004 SN +heater, I drain and fill.
                        • WakeSlayer
                          • Sep 2005
                          • 2069
                          • Silver Creek, MN
                          • 1968 Mustang
                          I have always been curious about the use of RV antifreeze for winterization. Is it an ecological purpose? I am all for less nasty stuff being used out there. However, I feel like an expensive performance motor, such as we have in our Correct Crafts, justifies the use of good automotive antifreeze, like you put in your cars. I lay my boat up for 5-6 months per year in fairly extreme temperatures, and want to have the best protection possible.
                          Why do some of you use this vs. Prestone mix, etc.
                          the WakeSlayer
                          • djbartholomew
                            • Mar 2008
                            • 53
                            • central illinios
                            I have always used RV antifreeze, started boating in 1970. That way I know that if it gets in the lake in the spring there will be no problem. I have always drained compleatly and fill till it runs out of the exhaust. Have never had any problems.
                            \"03\" ski 196 SE (for course use) current boat
                            \"97\" tige\' 2150 (for wakebording) current boat
                            \"72\" pontoon ( installing portable course) current boat
                            • OHLNautique
                              • 140
                              • TN
                              In my 89 Sport I would run the boat long enough to open the thermostat. Then drain the block. Then run antifreeze through it until it came out of the exhaust. Then drain the block again.
                              How about winterizing ballast tanks? Is it necessary? How is it done?
