06 210 red light and beep
  • d_nodixon
    • Sep 2008
    • 475
    • Hammond, LA
    • 2013 SAN 230
    Hey guys,
    I get a red light and a beep when backing off the thortle quickly
    Any advice???
    Thanks in advance
    2013 SAN 230
    2006 SSN 210 (SOLD)
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    RE: 06 210 red light and beep
    Keep it WFO?
    the WakeSlayer
    1968 Correct Craft Mustang
    • d_nodixon
      • Sep 2008
      • 475
      • Hammond, LA
      • 2013 SAN 230
      Sounds like an option, does not beep WFO, only when backing off the throttle quickly.
      After reading other posts looks like I need to check all my fluid levels.
      2013 SAN 230
      2006 SSN 210 (SOLD)
      • AirTool
        • 4049
        • Katy, Texas
        Mine does same when fuel is almost low. A hard stop sloshes enough to sound low fuel...but fuel settles out at 1/4 or more.
        Red light is from below tach...not check engine. I silence the alarm by pushing the up and down buttons at the same time.
        AirTool
        • d_nodixon
          • Sep 2008
          • 475
          • Hammond, LA
          • 2013 SAN 230
          Yep, under the tach, no need to silence as it only beeps for a second and the tank was over 1/2 full
          thanks
          2013 SAN 230
          2006 SSN 210 (SOLD)
          • AirTool
            • 4049
            • Katy, Texas
            If you look fast, you might see either "LF" or "LFUEL" in the LCD.
            Beep is like....."Beeeeeeeeeeeeeep"....catches me by surprise every time. I first think the alarm is on and I just noticed it because the engine is now quiet...but then alarm stops. By this time, I look at fuel gauge and level is fine.
            Crazy.
            • WakeSlayer
              • Sep 2005
              • 2069
              • Silver Creek, MN
              • 1968 Mustang
              Trans or Vdrive oil? I think that is typically what that light is for.
              the WakeSlayer
              • AuMDLST
                • Apr 2007
                • 870
                • Orlando, FL (Butler Chain)
                I would say either low fuel - even though you may still have over a quarter tank - or could be oil sensor - I get the low fuel every now and then and had the oil sensor replace due to alarm when coming out of the throttle - watch the dash units because they will flash the issue
                2006 SANTE 210 (Pending Sale)
                2005 206 TE (Previous)
                • d_nodixon
                  • Sep 2008
                  • 475
                  • Hammond, LA
                  • 2013 SAN 230
                  I will be watching the LCD this weekend. Sounds like a minor issue, hopefully so, only had the boat for a month!!!
                  Thanks to all
                  2013 SAN 230
                  2006 SSN 210 (SOLD)
                  • d_nodixon
                    • Sep 2008
                    • 475
                    • Hammond, LA
                    • 2013 SAN 230
                    Noticed your from Orlando,
                    That where I got my boat, quite a drive but well worth it.
                    2013 SAN 230
                    2006 SSN 210 (SOLD)
                    • AirTool
                      • 4049
                      • Katy, Texas
                      Thanks to all
                      This weekend I'll be watching Ike....from the sofa.
                      Hopefully no trees fall on my head and kill me.
                      AirTool
                      • Laptom
                        • Oct 2003
                        • 876
                        • Eindhoven, Netherlands
                        Our 06 was very similiear with a very sensitive low fuel level. Only one beep and the fuel gauge is pointing half full, but still a low fuel level error in the LCD for a split second when backing off the throthle.
                        • d_nodixon
                          • Sep 2008
                          • 475
                          • Hammond, LA
                          • 2013 SAN 230
                          Hope all is well in TX.
                          Low fuel it was. Also got another shorter beep and red light but no code in the lcd.
                          thanks
                          2013 SAN 230
                          2006 SSN 210 (SOLD)
