This may be an odd question. I have concerns about the die in my boat cover bleeding onto the sun deck upholstery over the winter. Black cover, white interior. Is this possible? If so any solution?
Tags: None
RE: Boat Cover Question
I don't think the material bleeds but it is possible the stitching may.
To keep the cover off the sun deck (for ventilation mostly) I use a pool noodle layed across the deck.Does pool noodle make sense? are they called pool noodles over there?
They are called pull noodles over here. That's a good idea. I was also thinking of covering it with plastic between the cover and the deck, but I'm afraid that will hold moisture and cause mildew.
ranger3: The cover was provided by the dealer but it is after market.
Does correct craft even make covers?
Mine is not made by CC, but it appears to be sunbrella (sp) material. What I meant was, I wouldn't think a CC dealer would provide you with a cover that would harm your vinyl. So far, I've had no issues and our boat is kept outside all the time.
