Timing on a 351
  • firemandave
    • 36
    • Bellingham, WA
    Timing on a 351
    How do I check/adjust the timing on my PCM 351? It has electronic ignition.
    Dave
  • TRDon
    • Oct 2007
    • 722
    • MN
    RE: Timing on a 351
    year of boat?
    • firemandave
      • 36
      • Bellingham, WA
      RE: Timing on a 351
      My boat is a 1992 SN .
      • TRBenj
        • 1682
        • NWCT
        RE: Timing on a 351
        Which engine/ignition? Im guessing you have the ProTec?
        1990 Ski Nautique
        NWCT
        • jos
          • 154
          • Netherlands Boxtel
          RE: Timing on a 351
          We use a portable stroboscoop timing light. Used on a running engine. Suitable to check all engines, clamp goes on spark cable of cilinder 1.
          • firemandave
            • 36
            • Bellingham, WA
            RE: Timing on a 351
            I have the 351 engine with a Protec ignition. I am familiar with timing am engine with a standard ignition but not one with an electronic ignition.
            • AirTool
              • 4049
              • Katy, Texas
              Re: RE: Timing on a 351
              In general, it is not a function of "electronic" versus points. The procedure is a function of the ECM that controls timing advance. If the ECM controls timing, you usually have to tell the ECM you want it to be in "set timing" mode. Not sure how to do that on Fords.
