Calibrating speedometer
  • Searay
    • Sep 2003
    • 51
    • Northeastern PA
    On a 1996 SN GT-40, with a 4 blade prop, what is the common way to check if to see if your speedos are reading close? A friend of mine says they should read 36 MPH at 3600 RPM. Does this sound right? Thanks.
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    It sepends on the pitch and diameter. The best way to check it is with a GPS system. As a rule of thumb with a 12.5X15.5 prop your friend is right.
    Nautiqueless in San Diego
    • SilverSpraySports
      • Jan 2004
      • 89
      • Fenton, Michigan
      Your best two bets are to either time it in a slalom course or get a GPS. The GPS is probably the easiest way. On a 1995 SN with a gt-40 and a four blade OJ prop, we run 3650 for 34 mph and 3850 for 36 mph. These come out with a pretty good time in the course.
      Hope that helps.
      -Doug
      Selling and Servicing Nautiques since 1981
      Silver Spray Sports Online <-- Click Here
