motor oil and v-drive oil
  • fitzee
    • Feb 2008
    • 127
    i know this has been asked probably alot but what is the oil of choice for pcm 330hp chevy and v-drive oil for a 06 210 team or what is used at the factory and if there are any other oils that need to be changed and what v-drive would be in mine manual lists like 3 different types
    thanks for the help not looking foward to putting the boat away for winter
    2006 Super Air 210 Team Edition(SOLD)
    1995 MB Sports boss 200 (SOLD)
  • NAWTEAK
    • Aug 2005
    • 192
    • Orlando
    RE: motor oil and v-drive oil
    u have the power plus vee tranny, that takes AFT(dextron III) fluid every 100 hours
    and the gearbox takes gear oil, should change that too. after first 100 hrs, then every 500/season
    engine oil is engine oil
    cheers
    • AirTool
      • 4049
      • Katy, Texas
      Re: RE: motor oil and v-drive oil
      And a ski boat's a ski boat.
      • fitzee
        • Feb 2008
        • 127
        so what should i use
        • bchesley
          • Feb 2006
          • 1252
          • Tyler, Texas
          If you have the new PCM v-drive you have to use their synthetic oil, but if you have the older model than its just straight 30W motor oil.
          2001 Super Air Nautique
          Python Powered
          100 Amp Alternator
          Dual Batteries
          Many upgrades coming...
          • fitzee
            • Feb 2008
            • 127
            when changing oils
            1.15w40 motor oil
            2.pcm v-drive mobiltrans shc 50 synthetic
            and on the motor it says to use dextron111 in something what am i missing
            • fitzee
              • Feb 2008
              • 127
              can someone help
              • AirTool
                • 4049
                • Katy, Texas
                Originally posted by fitzee
                can someone help
                pm sent
