So I got my starter and laternator back from being rebuilt, got everything hooked up, juiced up the battery, and turned the key. Nothing but a click every time I tried to start it. For those that remember I had some water-in-transom issues and I have a '96 with a GT40. My question is this - do I need to get after my relays next?
RE: starting woes cont
starter relay as stated before
HUMAN BUILT = HUMAN FIXED
switchbait.com
Check all connections from the battery (both to the block for ground and all the way to the starter for +12V). A dirty or loose connection will cause the symptoms described.1990 Ski Nautique
NWCT
