Temp Gauge Stopped Working
  • BP22
    • Jan 2007
    • 248
    • Covina, CA
    • 2006 Super Air Nautique 210
    When I fired up my boat this weekend my engine temp gauge was not working at all, no movement. I checked the fuses and even gave the gauge a few "love" taps...nothing. It worked fine two weeks ago.
    My boat is a 2006 SAN SE with the Faria analog gauges.
    What else should I check?
    Thanks.
    Brandon
    2006 SAN 210
  • TravisFling
    • Mar 2008
    • 889
    • London, Ohio
    • 1989 Ski Nautique 2001
    RE: Temp Gauge Stopped Working
    Check the wires to the back of the gauge and follow them to their home. You probably have a wire loose if everything else is working properly. Otherwise it might be the sender.
    Travis Fling
    Choctaw Lake
    • BP22
      • Jan 2007
      • 248
      • Covina, CA
      Re: RE: Temp Gauge Stopped Working
      Thanks Travis. Looks like I am going to have to pull the dash.
      Brandon
      2006 SAN 210
      • JUST-IN-TIME
        • 293
        • ON YOUR BOAT
        RE: Re: RE: Temp Gauge Stopped Working
        see if u have 12v on the purple wire on the gauge first
        then find the sensor and remove the wire
        ground that out, it will read high temp with key on
        if not, check grounds first before replacing the gauge
        HUMAN BUILT = HUMAN FIXED
        switchbait.com
        • seth
          • Jun 2008
          • 549
          • Santa Barbara, CA
          • 01 SAN-sold
          I second pulling the dash and checking wires. It has happened on my temp and oil gauges this summer.
          • BP22
            • Jan 2007
            • 248
            • Covina, CA
            Re: RE: Re: RE: Temp Gauge Stopped Working
            Thanks Seth. Was it just a loose wire?
            Brandon
            2006 SAN 210
            • BP22
              • Jan 2007
              • 248
              • Covina, CA
              Pulled the dash and checked all the wires. Everything looked OK.
              When I turn the ignition key to On the gauge gives a little bump and then settles back down with no reading.
              Any suggestions???
              Thanks.
              Brandon
              2006 SAN 210
              • BP22
                • Jan 2007
                • 248
                • Covina, CA
                Gauge has the 12v purple wire. Where is the sensor located?
                Thank you.
                Brandon
                2006 SAN 210
                • JUST-IN-TIME
                  • 293
                  • ON YOUR BOAT
                  RE: Re: RE: Re: RE: Temp Gauge Stopped Working
                  sometimes buy the t-stat, usually
                  i forget know what color is PCM, but mercs are tan
                  switchbait.com
                  • 8122pbrainard
                    • Jul 2007
                    • 255
                    BP,
                    In this thread on heater installing, there's a picture of the typical temp. sender.
                    http://www.planetnautique.com/index....ic&t=12757
                    You will probably have two wires running to the sender. When you ground out the wire to check the gauge, make sure its the one that runs to the gauge and not the one to the ECM.
                    • BP22
                      • Jan 2007
                      • 248
                      • Covina, CA
                      Thank you 8122.
                      Brandon
                      2006 SAN 210
