Replacing keypad with real key
  • jeclarke
    • Sep 2008
    • 57
    I just purchased a model year 2001 Ski Nautique 196. Had a 5 minute test ride and then had it winterized and put away until May, 2009. This is torture!
    The previous owner told me that the keypad was temperamental so I've been reading on this site about replacement keypads running $400-$500.
    Surely someone has replaced this high tech unit with a conventional ignition switch and key. Something that will always work.
    If you know how to make this change I sure would appreciate hearing what you did.
    thanks
  • j2nh
    • Dec 2003
    • 628
    • Spread Eagle Wisconsin
    Congrats on the new boat!
    Check this thread:
    http://www.planetnautique.com/index....ghlight=keypad
    Richard did some surgery on his keypad and had success. Might be a good winter project for you.
    2018 200 Team H6
    2009 196 Team ZR 409
    2005 196 Limited ZR 375
    2003 196 Limited Excalibur
    1999 196 Masters Edition
    1987 ProStar 190
    • KenG
      • Oct 2006
      • 29
      • Minnesota
      • 1991 Ski Nautique 1997 Ski NautiqueW/ GT 40 2006 206
      Re: Replacing keypad with real key
      thanks
      With regards to a key pad going bad,does anyone have a plan for starting and operating the boat if the key pad goes bad while on the lake. (hotwire)
      On a drive (throttle) by wire engine if a wire is run from battery to pos side of coil and starter sol jumped will the throttle work.
      2006 Ski Nautique 206
      1997 Ski Nautique CB
      1991 Ski Nautique
      • jeclarke
        • Sep 2008
        • 57
        j2nh,
        Thanks for pointing me to Richard's fix.
        Since apparently the 00-01 keypads are prome to fail early, unless I know that the manufacturer changed the design, why would I spend $500 for a replacement keypad that is identical to the one that failed. I'll be in the same situation in a few years spending another $500.
        I'd still like to find out how to replace the keypad with a conventional switch and key.
        Has anyone done this?
        • 2gofaster
          • 671
          I believe that the problem you run into is that the keypad and switches for accessories are integrated together in the limiteds via that box under the dash. I think you'd have to replace that entire system and it's going to be far more expensive than $500 to do that just to get a key'd ign switch.
          Shane Hill
          2014 Team 200OB
          67 '13 Prophecy
          • AirTool
            • 4049
            • Katy, Texas
            I've read where this has been done for at least certain years and you will have to hard wire every device. My 06 keypad has only three or four wires going to it...and many functions which means it is communicating back to the brain box with a signal...not dedicated voltage to each device.
            So, you'll have to have a switch that powers the gateway, then a switch or button for every other device on the pad.
            I'll try to find the other post.
            AirTool
            • M3Fan
              • 1034
              I don't know about that. As far as I know, my keypad is original on my 2000. So that's 9 seasons of use with zero problems. There are many, many 2000-2002 boats with those keypads that have never had a problem with them.
              2000 Ski Nautique GT-40
              2016 SN 200 H5
              www.Fifteenoff.com
              • jhiestand
                • 778
                • Columbus, Ohio
                • 08 Super Air 210
                I've never heard of issues with them, either. The digital gauges, yes, but not the keypad.
                After having experienced keys left at the house, dropped in the drink (& float chain broke), lost, etc., I don't know why other mfg's don't use keyless ignition.
                '08 Super Air Nautique 210
                • AirTool
                  • 4049
                  • Katy, Texas
                  I agree...but I wouldn't integrate it with all the other functions like bildge blower, etc.
                  I'd hardwire those switches either to the gateway for logic or directly to the device.
