Carb issues, high idle and stalls on full throttle from idle
  • simwhatley
    • Oct 2008
    • 3
    Hi,
    I have a 1998 Air Tique 351 with Holley Carb. I brought it in to a mechanic the other day to have the fuel line resealed as the seal was broken when working on it and it was leaking gas.
    Since I've gotten it back, the idle is running pretty high, 1,500 or so and when I try to get a skier out of the water, going from idle to mid-full throttle, it stalls. I have to slowly get past a certain point in the acceleration before I can open it up, which is difficult for getting people up out of the water.
    Any thoughts. Hoping I don't need a rebuild, do you think there could still be a pressure issue on the fuel line?
    Thanks,
  • JUST-IN-TIME
    • 293
    • ON YOUR BOAT
    RE: Carb issues, high idle and stalls on full throttle from
    soulnds like you need to adjust the carb first
    down the manual from here
    HUMAN BUILT = HUMAN FIXED
    switchbait.com
