Bilge Water
  • larryswift
    • Dec 2003
    • 33
    • Sandmound Slough Oakley CA
    Bilge Water
    How much water should be in the bilge when you haul the boat and let the water drain out of the stern plug when the boat is on the ramp. I have a 2000 SAN and just had the prop, strut and shaft replaced and before the boat was fairly dry. Now water runs out of the stern plug whole for about 30 to 60 seconds at a steady stream.
  • Socbum
    • Oct 2003
    • 268
    • Columbus, Ohio
    • 2002 210 Super Air Nautique Previous 1987 America
    Mine is usually bone dry.
    You should have the shop check out the boat on the water.
    SocBum
    2002 SAN <== Current Boat
    1987 American Skier Advance <==First Boat
    • larryswift
      • Dec 2003
      • 33
      Thanks I just called the shop and I am bringing it in tomorrow. Thanks again.
      • Rick
        • Mar 2004
        • 1250
        • San Diego, Ca
        It sounds like the packing nuts need to be tightened more
        Nautiqueless in San Diego
        • SolidCitizen
          • Jul 2004
          • 5
          Definitely tighten the prop shaft packing or replace it. If that doesn't solve it, it may be a hull-penetrating screw that backed out.
          I had a good amount of water entering the bilge of my 94 ski OB, and replacing the shaft packing didn't help. With the help of friends I finally tracked the leak down to the stern plastic covers just beneath the ski deck. One of the screws that hold those on had backed out. A 15 cent fix later and my friends finally stopped calling her the titanic.
