ZR6 winterization
  • Laptom
    • Oct 2003
    • 876
    • Eindhoven, Netherlands
    ZR6 winterization
    Have done all my winterizations myself, but it's the first time I need to do it on a closed cooling engine (ZR6). As far as I can seen the engine doesn't need to be warm for this winterization. The thermostat is in the closed cooling loop. The winterization is just for the raw water pump, heat exchanger and exhaust pipes. So we can just start the engine and let the anti-freeze being pumped inmidiately. Am I correct?
