Has anyone modified their pre-2006 Ski Nautique to accept Zero Off speed control?
Re: RE: Zero Off in Pre 2006
Originally posted by gride300im not saying it can't be done it's definitely designed for throttle by wire, not cable. and stay away fromt he p.p. stargazer2006 Ski Nautique 206
1997 Ski Nautique CB
1991 Ski Nautique
RE: Re: RE: Zero Off in Pre 2006
I like PP stargazer and have had no problems with it. I would recomend it for anyone that doesnt have dbw. I have heard they are supposed to have some updates avialable to it that will mirror the pull of Zero off soon.2005 Ski Nautique 206 SE, Acme 422, PP SG 8.0, ND Tower
Prior Boats:
1999 Ski Nautique GT-40
www.skiersofknoxville.org
It can be done. Just not economically. To do it will require that you change out the fuel injection computer, complete engine harness, throttle assembly, etc. This in itself will run you over $3000, then you have to get the Zero Off. You're looking at $4500-4700 before labor, minimum. I think the gauges in the limited's still run off the same canbus interface on the 03-05 as the 06+ does so those shouldn't have to change. You also have to make sure that you get the 07 and newer ECM as the 06 ECM will not work with Z0.Shane Hill
2014 Team 200OB
67 '13 Prophecy
