I have a 2008 model 206 which is equipped with the optional dash pod circuit breaker box, the one which has the sixteen vinyl tubular covered shields. Can anyone advise how to access the rear of this breaker box in order that I may connect a fresh water shower to one of the spare dash pod switches? Looks like the base of the toe board is hinged at the floor but I'm not sure if one is meant to pull the top of the panel to release it?
RE: Access to Circuit Breaker Box
Thanks AuMDLST. Removed toe board no problem. The Optional Dash Circuit Breaker Box consisting of the 16 vinyl tubular covered circuit breakers appears to be a sealed black box. I'd like to hook up a 12 volt bilge operated fresh water shower to the spare 12V Limited Ignition & Switch Panel, can't seem to find where to to hook up my shower wiring, appreciate any advice.
