DIY shower question
  • AirTool
    • 4049
    • Katy, Texas
    Re: RE: Re: RE: Re: RE: DIY shower question
    Originally posted by Hollywood
    That's great but you don't need a 1" line feeding your shower. I couldn't find just one part to make my T either, so it ended up being a 1" through with a 3/8" female NPT attached to a 3/8" male NPT - 3/8" barb. The T fitting is gray PVC and the barb is opaque. These 2 parts are just a couple bucks you can buy one at a time from Ace Hardware.
    The 1x tee was just an example. I don't know what size he wants or needs.
    Here is a link to the insert fittings and all catalogs. They have a 1x1/2" insert tee or he can use a combination tee and combination elbow like you did.
    http://www.lascofittings.com/Product...nserts.xls.pdf
    http://www.lascofittings.com/Products/productpdf.asp
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      RE: Re: RE: Re: RE: Re: RE: DIY shower question
      I am going to remove the shower from my boat in the spring. If anyone is interested I was thinking like $50 plus shipping. I had meant to do it prior to winterizing but neglected to buy the plus for the block. Let me know.
      the WakeSlayer
      1968 Correct Craft Mustang
      • Hollywood
        • Sep 2003
        • 1930
        • WIIL
        WS, put me on the list for your shower. I will ask my buddy if he is interested and get back to you ASAP.
        • scoootnz
          • Feb 2008
          • 61
          • New Zealand
          If hollywood doesnt take the shower wakeslayer I'm interested will be a good winter project for me at that time of the year. Your spring my fall
          • WakeSlayer
            • Sep 2005
            • 2069
            • Silver Creek, MN
            • 1968 Mustang
            HW, Let me know. I have only run the shower when winterizing. I have the valves, showerhead, hoses, pump, and whatever else there is.
            the WakeSlayer
            • MUSHEZ
              • Jul 2008
              • 24
              • Mangakino, New Zealand
              #21
              Originally posted by Quinner
              This is the factory installed shower cold water supply on my Excalibur.
              Hot taps off the block.
              That can't be a factory installed shower of a Nautique can it Quinner????? Our Nautique dealer said that Nautique never have offered a factory shower unit, and it is against CC terms to all dealers for them to be involved in any way promoting or fitting aftermarket shower units to Nautiques. It has to do with Nautiques hard line stance of carbon monoxide poisoning, as you need to have your engine running to operate them, and most use them on the boarding platform to use them.
              Hamish Russ - New Zealand
              Current - 2006 Super Air Nautique 220 Team Edition
              ex 2006 Ski Nautique 206
              ex 1989 Sea Ray 180BR
              ex 1979 15ft Plylite
              www.wakepro.co.nz
                #22
                Correct Craft did install showers in boats prior to 2003. About 2003 they decided not to make then available. On boats with the 6 liter engine you could not put a shower on, because of the closed cooling system.
                • Quinner
                  • 2246
                  • Correct Crafts
                  #23
                  Hamish,
                  CC offered showers until 05', ordered showers on a 99' and an 05'. They sure appear to be factory installed, otherwise the dealer installed them, all I know is when I picked up the boats the showers were there as I had ordered them.
                  Daniel,
                  Check out the 05' brochure on CCFan, showers are listed as an option, pretty sure that was the last year. I have read you can rig a shower in a closed cooling engine although I have never seen one done.
                  05' Brochure - Item 8
                    #24
                    I worked in a Nautique dealership until sometime in the Spring of 2003, and I knew that there were factory showers installed in the boats, and I also installed showers in boats that did not have them from the factory. I did not really pay attention to exactly when they were not installed anymore by the factory. I also think that if you went into a Nautique dealer, and wanted to buy a 2009 Nautique with an Excalibur 343 engine and wanted a shower, and the shower was wanted to close the sale, you could probably could get a 2009 Nautique with a shower. I have seen a Sport Nautique with a trolling motor bracket mounted on the swim platform.
                    With the closed cooling system on ZR-6 motors, there is not really a supply of hot water for a shower. The warm raw water out from the heat exchanger is not really hot enough to be used for a shower.
                    In 2003 there was already talk of discontinuing showers in all the boats, because of the CO problem.
                    I believe there is factory wiring installed in all the 2003 boats that used the touchpad control system. (Team, and Limited boats) It is less expensive to mass produce the electrical system, and controls the same, and install it all the same, than it is to make different variations for each boat and model. That is why if you have a 2000 or so Ski, or Sport Nautique, it also has touch pad switches for raising the electric hatch the was only on one model of Nautique in 2000, the "Real or Classic" Super Air.
                    • MUSHEZ
                      • Jul 2008
                      • 24
                      #25
                      Interesting - you learn something new each and every day.
                      www.wakepro.co.nz
                      • cat1168
                        • Dec 2005
                        • 73
                        • Connecticut
                        #26
                        I have a 05 196 and from what my dealer told me I had the last factory installed shower from CC. They stopped it because of a lawsuit in California, some one sued CC for smelling exhaust when using the shower. They did not win because of all the warning labels, but it did cause CC to stop factory installing them in 05.
