Leave unbuffed WAX on all winter...
  • wakecrashin
    • May 2007
    • 376
    I store my boat at Marine Max and the service guy there recommened that I put some wax on, unbuffed all winter and then come spring buff it off. Anyone ever heard of this? He said it helps protect the gel coat all winter.
    RE: Leave unbuffed WAX on all winter...
    Part of this sounds like a good idea, however if there is any dirt or dust that settles in the wax, it seems that buffing the dirty wax off might cause problems.
    At least if you do this, wash the boat before you buff the wax.
    • j2nh
      • Dec 2003
      • 628
      • Spread Eagle Wisconsin
      Not sure if I understand the reasoning behind this. Depending on the kind of wax this stuff could be a real bugger to get off in the spring.
      Buffed wax fills in the pores that naturally occur in fiberglass. Unbuffed would do the same but would also provide a less than slick surface for contaminants to stick to. Go to buff it off and you will grind those contaminants into your finish.
      Are you storing your boat inside or outside? Sun is the number 1 enemy of pretty much everything so the key is to keep the boat covered and sun exposure to a minimum.
      2018 200 Team H6
      2009 196 Team ZR 409
      2005 196 Limited ZR 375
      2003 196 Limited Excalibur
      1999 196 Masters Edition
      1987 ProStar 190
      • wakecrashin
        • May 2007
        • 376
        Im keeping it out side.. any ideas on how to keep the sun off of it?
        • j2nh
          • Dec 2003
          • 628
          Tarp or maybe one of those inexpensive portable tent garages would work for keeping it out of the sun.
          If you do tarp it up make sure that you don't seal it up completely or you may end up with a mold problem.
          Add a coat of well buffed wax, 303 protectant (has a UV block in it) on top of that and you should be good to go.
          2018 200 Team H6
          1987 ProStar 190
          • TRBenj
            • May 2005
            • 1681
            • NWCT
            That plan sounds fine. Just wipe the gel down with acetone before buffing in the spring. That will remove the wax easily and wont harm the gel.
            1990 Ski Nautique
            NWCT
            • Center87
              • Oct 2008
              • 56
              • Vernon, B.C.
              • 2005 Super Air Nautique 210 Team Edition
              It may be best to wax it and then buff, cover it with a tarp and come spring time give it a wash and re inspect if need be re wax or better yet buff it with a wax polish from Mcguires. This is more work but your boat will look better and always maintain that showroom shine. I agree that if you leave the wax on you may attract fine dust and other debris that can harm your gelcoat when you remove the unbuffed wax after the winter. Acetone is a chemical that can be used to remove any wax from a gouge before you apply new gelcoat to the repair it can also remove some of the color so I would advise to not use it at all unless you are repairing your gelcoat.
              Hope this helps,
              "Remember Kids Keep Your Head Up, Go To The Net And Good Things Can Happen"
              2005 SAN TEAM
              2000 PRO AIR
              1992 Ski Nautique
              • TRBenj
                • May 2005
                • 1681
                • NWCT
                It makes absolutely no sense to wax the hull and then buff it. Wax protects the gel, buffing removes it (leaving it smooth, hence the shine). The wax needs to be removed for buffing to have any effect. Also, wax will not attract dust- instead it will add a protective layer and make it easier to clean in the spring than if left unwaxed. Again, acetone will not harm gelcoat. I often use it to remove the residue left by polish before putting on wax.
                1990 Ski Nautique
                NWCT
                • wakecrashin
                  • May 2007
                  • 376
                  What kind of wax comes off easy in the spring?
                  • TRBenj
                    • May 2005
                    • 1681
                    • NWCT
                    Acetone will remove any wax very easily.
                    1990 Ski Nautique
                    NWCT
                    • jpduster
                      • Apr 2008
                      • 106
                      • Sydney, Australia
                      • 2008 210TE
                      'wax on wax off' ???
                      • SuperSquirt
                        • Apr 2008
                        • 534
                        • Tennessee
                        • 2008 SANTE 210
                        For the record, Correct Craft does not recommend using Acetone on your boat's paint.....it will eat up grit and all of your wax, and too much could ruin your paint job. That's the answer I got when I talked to one of their Orlando factory guys.
                        I say be careful, because I know some car mechanics use this potent chemical to flush automobile fuel systems and clean out exhaust systems.
                        • Hollywood
                          • Sep 2003
                          • 1930
                          • WIIL
                          • 8122pbrainard
                            • Jul 2007
                            • 255
                            • Unknown
                            SS,
                            Have you painted your boat? Just wondering because of your acetone comment.
                            • SuperSquirt
                              • Apr 2008
                              • 534
                              • Tennessee
                              • 2008 SANTE 210
                              No, I have not had it painted, I thought about using it on the interior fiberglass because it wasn't buffed from the factory nor my dealer (had a lot of shop residue on it). Instead, I used a buffer and a little bit of cut wax and polished it.
