Where is lake temp sensor on limited?
  • 2gofaster
    • 671
    Ok, my lake temp sensor which shows in the lcd of the tach on my 05 limited is about 10-12 degrees off, so I need to look into that. On the limited's, where is it? I'm not finding anything that looks like it at the hull or engine area. Thanks.
    Shane Hill
    2014 Team 200OB
    67 '13 Prophecy
  • MikeC
    • Apr 2007
    • 535
    • Georgia
    • 1999 Ski Nautique (Python powered) 2017 GS22 (sold) 2005 SV211 (sold)
    RE: Where is lake temp sensor on limited?
    Check the raw water intake line - it should be located between the shutoff valve near the through-hull fitting and the strainer.
    • 2gofaster
      • 671
      I saw that. It's not a conventional sensor there, but a big T in the line with a compression fitting and 1/4 hose going somewhere. Hmmmm. I wonder if it goes back to the black box where the pitot's connect too.
      Shane Hill
      2014 Team 200OB
      67 '13 Prophecy
