Air & Water Temp Sensor locations ??
  • jaybird
    • Oct 2008
    • 516
    • North Alabama Lake Weiss
    I assume all CC with the Faria gauges must have the same sensors, I have a 2003 Nautique Limited 226 and the water temp reading is just not correct. Where are the air and water sensors?
    2012 Team Ski Nautique ZR409
    2011 Sport Nautique 200
    2008 SANT 230
    2003 Air Nautique 226
    1988 Martinique
    1979 Nautique
    1978 Tique
    1976 Tique (First New Boat)
  • 2gofaster
    • 671
    RE: Air & Water Temp Sensor locations ??
    2002-2005 the lake temp sensor is T'd into the raw water inlet tube between the strainer and the through hull fitting. It screws into that T and the wires run back to the Faria gateway box in the trunk. Nautiques of Orlando quoted me $24 for a new sensor.
    Shane Hill
    2014 Team 200OB
    67 '13 Prophecy
    • jaybird
      • Oct 2008
      • 516
      Thanks, Shane
      2008 SANT 230
      1988 Martinique
      1979 Nautique
      1978 Tique
      • Proud2BeCC
        • Mar 2004
        • 201
        • Warsaw, IN
        • 2002 Sport Nautique
        I've got a 2002 Sport Nautique. I'm not getting any reading at all for the air or water temperature. Does this sound like a sensor issue or an electrical problem?
        _____________________________________________
        Proud2BeCC
        2002 Sport Nautique
        (NDT) New Dimension Tower
        TowerBinimi Binimi Top
        Clarion CMD5
        • igkya
          • Oct 2003
          • 227
          • Minden, NV
          • Club boat 2005 196
          Where is the air temp sensor located?
          • 2gofaster
            • 671
            I bet it's built into the gateway box that's in the trunk.
            Shane Hill
            2014 Team 200OB
            67 '13 Prophecy
            • jaybird
              • Oct 2008
              • 516
              Proud2be............it is an option on some boats, are you sure you have it. Generally if you have no reading its not installed....not sure what you are seeing on your display...blanks ????
              2008 SANT 230
              1988 Martinique
              1979 Nautique
              1978 Tique
              • Proud2BeCC
                • Mar 2004
                • 201
                • Warsaw, IN
                Jaybird.....Yes, I had my air/water temp display working correctly the first two years after I bought my boat used in 06/07. This summer, it did not work. Not seeing any digital numbers or anything on the digital display.
                Thanks,
                Proud2BeCC
                Proud2BeCC
                2002 Sport Nautique
                Clarion CMD5
